My anker charger doesnt fit Samsung s10 or 20. Worked on j7. Can i get an adapter or do i need new power stations
Does anyone know why my Anker wont fit s10 or s20
Hi @Jeff_Sacks
The S10 and S20 have a USB C type charging port and the J7 has a USB Micro port, so you’ll need another cable.
Keep the old one though as some equipment still use USB Micro.
Nearly all my equipment does!
I find with may devices with different connections, I went toward a 3 in one cable.
Anker does have a powerline cable that also comes with adaptors. I bought the one where it has a micro on the initial cord but has two attachments with a lightening and a usb c.
Make sure you buy a USB C cable lol
