Does any of the homebase camera listen to sound for glass breakage/fire alarm?? It needs to be a homebase camera like E, 2, 2pro, 2C, 2C pro in order to also work with the alarm keypad and sensors. Thanks in advance.
Do any of the Eufy homebase connected cameras listen to sound for glass breakage/fire alarm?
As far as I know the eufy cameras are not designed to sense glass break or fire alarm specific sounds. They do have normal sound detection capability which may pick up those sounds as you need as well though.
You know that is interesting considering that the cameras have an AI chip that could easily be used to analyze the real time audio from the mics without wasting as much battery energy as it takes to real time track video.
