Though I don’t have the impression that this forum will ever be read bij someone from Eufy; maybe someone else has an answer.
I just bought the Eufy doorbell (model T8210) and installed it.
I have installed as with external power and the app shows the plug icon so it sees i’m on external power.
However when I steam the camera I keep getting messages that extensive streaming is bad for the battery and I have to answer yes/no to continue.
I guess that is also the reason why I can’t stream only a short while on my Google Nest Hub before it is interrupted.
Is there a way to disable the messages so I can stream uninterrupted?
I could fake it bij removing the device and installing it as the non battery doorbell. Will that help?
