I am trying to decide between:
and
Both have 2 USB-A plugs. Both plug into the wall. Except the PowerCore also acts as a battery when it’s not plugged in.Is the output for the PowerCore fusion 5000 2.1 amps PER port (so 4.2 amps total)?
Whereas the PowerPort Elite 2 is 2.4 amps per port, so 4.8 amps total?
For an iPhone 7 or iPad Mini & Pro, the Fusion 5000 will charge them at the same rate as the Power Port Elite 2, right? Saw this table online - looks like the fastest an iPad would normally charge is 2.1 amps.
