Date label color
The date label is white color and sometimes with zones bright don’t see very good.
Other cameras have the option to change color number to black if the zone back is so bright.
  • It’s possible to implement this function in all camera models?
    Best regards
I can see how this can be very annoying, maybe in a future update they will include the option to change the colors
Our CCTV at work will change text/graphics colour depending on its background.
So would hope it would be easy to be make the graphics users configurable @ANGEL17
But as always, it’s making sure your voice is heard.
Have you mailed support?
support@eufylife.com
Great suggestion to pass along. As mentioned earlier eufy has a separate forum.
Yes, I send email to Support.
Thanks!
