Connect a Doorbell Chime with a Home Base 2 and a Battery Doorbell
Hello,
I have connected a Battery Doorbell to my HomeBase 2 and everything is working fine.
After some time, I bought a Wireless Doorbell Chime. I added it successfully to the HomeBase 2 but it doesn’t make any sound when I press the Doorbell button and the Doorbell and the HomeBase 2 ring.
I didn’t find any configuration in the App to connect the elements.
How can I tell the Chime to react when the Battery Doorbell button is pressed?
Thank you in advance
Best regards
Fabio
I also am having this issue. Did you ever find out how to fix it?
Hi, No I switched to Home Base 3.
The “old”-Video-Doorbell is working seamless with Home Base 3
