I bought a Nebula Max in China (M2) and I would like to delete the pre installed Chinese apps - and preferably replace them with Western alternatives when I take the Nebula out of China - How can I do this ? I have virtually no technical knowledge.
Chinese Nebula capsule max
Check out the video in my post Here
Switch the language to that of your choosing and then you can add or delete apps.
You might also look into contacting support and asking them for the developers passcode, this will allow for firther customization and access to the google play store
