I have a car charger that converts my cigarette lighter to a 120v 80w household outlet. Can I safely use this to charge my PowerCore 26800 PD using the Anker * 30W USB-C Wall Charger? Thanks!
Charge with 80W output
So your using an inverter in your car, with the anker wall plug? Then yes you can use it to charge your batterypack, the wall plug will only output ad much power as the batterypack is requesting so you will be fine
Thank you Tank! I did not want to take the chance of frying my new unit. I had somebody look at my converter once and they said that it seem like it was putting out excessive power. Thanks again, Andy
