Certified Chromebook-Compatible Accessories
Charging accessories for Chromebook now available at Target, Costco, Best Buy, Amazon, and through Google’s enterprise and education programs.
E57E1C00-CECE-43EB-8387-517E677089AA
Coming Soon
PowerPort III 60W (Two Ports) — $59.99
C68FBF20-ECED-4100-A495-8F621CF99D27
PowerPort Atom III Slim 30W (One Port) — $29.99
BC6F9B74-6BB4-48D3-9F7F-55900436D1DE
PowerDrive+ III Duo — $29.99
48958F9D-B9F2-4D59-9C91-4D040D45D88C
PowerPort III 65W (One Port) — $59.99 (Black Version with PowerIQ 3.0 Also Announced)
663E4955-6C8C-4CE0-9794-C1891A452A0D
Are you confident those last two images belong together? Looks physically impossible, and illogical combination.
The last image seems to belong with the 2nd image.
Not exactly sure what you mean, @professor. The page is incorrect because it mixes up the two wall chargers with dual ports.
This is physically impossible
But this
Is just a different placement of this, which is physically viable.
What about it is impossible?
Think the main image is showing the third adapter already in place…not an additional adapter to add on top…
Yes that makes sense, you solved it. I was wrong.
put here
Makes this
Which is very different to what they usually did of a folding built-in US which you then slid over an adapter.
Finally. How many times we said to make international versions!?!?!
Just do it on everything forever.
Oh, that’s what he was talking about. You’re right, @ndalby! @AnkerOfficial’s post from January was correct.
8ea6e827ee81dc0925c8797d6dbe5d415ab64e8d
A small cutout around the adapter is visible.
