I plan to buy PowerPort Solar 21W, also it would be perfect, if I could store solar power into a PowerCore. Let’s say PowerCore Essential 20000 PD or PowerCore+ 26800 PD 45W. However, as a newbie, I’m not sure if it is even possible.
Based on the answer from other question, seems that it is not recommended. I’d like to double check it here.
If it is possible, which PowerCore can work with Solar Panel, and do I need to add any unit in between?
If it is not possible, is there any way that I can store solar power?
Any advice would be greatly appreciated.
