When other person answer call when am connected to bluetooth, he’s getting some weird sound first gizzz after that noise cancellation works like 2k rupees bluetooth
Not like life note and liberty 2 as i used them previously
Need improvement in Noise cancellation and connection issue in my liberty air 2
Done software update too…
Just 2 to 3 meters sound is breaking and again continuing randomly
Call and connection issue
This model is one of our newest products. We deeply appreciate your detailed answers to discover the root cause of the problem:
- What is the model and OS of the device you are connecting the headphone with?
- Are you having this issue with regular phone calls or with an App you use for calls (e.g. Skype, Whatsapp etc.)?
- Where are you usually when the problem happens? Indoors? On a busy street?
We kindly ask you to try the following troubleshooting as those have proven to often times already help:
-Use the default phone call on another phone to see if it makes any difference.
-Download the Soundcore APP and upgrade the firmware to the latest version
Asus 6Z and Android 10
Regular phone calls
Indoors and busy streets both, gizz sound at first when answering call is there and then in busy streets noise cancellation doesn’t work upto it’s mark like i used before life note and liberty 2
