Bolder By Anker is an Amazing Flashlight
I can attest for that one… just need to be careful in plugging in the converted bits as the main is micro USB, and you could put it on backwards…
I loved mine for the two years it lasted. Was great for hunting. Then recently just wouldn’t’ take a charge. While plugging it in the charging indicator light would occasionally flicker but not stay on. Even tried a few other cables and same result. I also have the LC 130 and so far it’s still going good.
Open it and test the battery.
if its gone, replace it.
The flashlight is worth to try that.
But you should try to clean the socket first.
May be there is some debris which causes that problem.
I had that on one of my LC40 was just still in warranty and got a replacement.
It happens.
All of Anker’s original flashlights were dismantlable and I got 2 of each type so if a part fails on one I can move it’s remaining working parts over.
However they moved to non-serviceable designs later meaning outside of warranty I’m stuck.
I’m a big fan of serviceability, it’s what you do after warranty expires.
Beside cables, you should try a different plug in as well. As cables can fail, the plugs can be an issue as well.
