I bought a new soundcore 2 and try to play music suddenly it start to disconnect and reconnect repeatedly. What Cam I do to stop it
Bluetooth auto disconnecting
Do a reset, remove the speaker from the bluetooth list of your device and connect it again.
Is it the same when you connect the speaker to another device?.
What device are you using?
Clearing your BT pairing records for the speaker and completing a restart of the device before trying a new pairing normally resolve most issues.
I have clear and try repair with another device the problem still continue
I have reset the speaker and clear from my phone. The problem still continue
