Battery replacement for bluetooth speaker
Anker
#1
Hi everyone,
I purchased an Anker bluetooth speaker in 2015 and now, it won’t charge completely. The speaker will work for a few minutes after charging for hours. I am looking to see if I can change the rechargeable battery, what type to use and how do I access the battery (ies).
The model I have is Premium Bluetooth Speaker (https://www.anker.com/products/variant/Premium-Bluetooth-Speaker/A3143011)
Thank you for your help.
#2
Hi @topjobs , taking into account the uncertain hassle of stripping down the speaker and then the added cost of the batteries I would go with purchasing a new speaker, either the same model if it has served you well or one of the update speakers that have recently been released. The speakers often appear in stages with a discount and you will have the benefit of 18 months warranty again.
#3
Hi ndalby,
Thank you for your reply.
Well I thought of that of course, but I would prefer not trowing away so much hardware.
I would like to just find the way to open the speaker, but so far I can’t find anything. Do you know where I could find the instructions to open this speaker?
Thank you again.
#4
you can change pin to your music. Please follow video :enter link description here
#5
Take off the battery with a knife, great video… :thinking:
#6
I know this thread is old, but why would you refer someone to take apart a speaker yet alone a battery with a knife?
If your gonna change the batteries do it proper with the use of a soldering iron. And use the right kind of batteries not some off the shelf low quality China knockoff
#7
VIDEO for you.
