Battery Notification
Is it possible to turn off the battery notification on the earbuds (liberty air 2)? I use my earbuds to drown out unwanted noise while I sleep, but the “battery low” warning is too loud and wakes me up in the middle of the night.
Don’t think there’s anyway to disable that. Unless of course you have them turned off already
If your listening to music and want them to last all night. Then lair each earbud to your phone individually if your phone supports dual Bluetooth, then each earbud will last roughly 8 hours this way
In would use such ones.
No battery, much more comfortable and if you “lose” one there is no problem!
But no music of course, no lullaby :rofl:
index
