Bass Up button while in Custom EQ
Here’s a suggestion for the Motion+:
Currently, when pressing the BassUp button while using the Custom EQ, the whole EQ mode changes to the preset Bass Up EQ.
Instead, while in Custom EQ, it would be better that pressing the BassUp button increases the low frequency sliders in the Custom EQ, and keep the Custom EQ active. For example: 80Hz +3dB / 150Hz +2dB / 300Hz +1dB
Looking forward to hear what you think!
Best,
Simon
Thank you for your kind suggestion, we will pass this advice to our support team for future product development :relaxed:
I totally agree that this is how it should work. The way it currently works doesn’t really make sense…
It could easily be altered via a software update as well…
Any news on this topic?
