tengo unos audifonos nb10. los usé unas 10 veces y ya no encienden. que me recomiendan?
audifonos anker
I don’t know if anyone here speaks Spanish so I’ll just answer in English. But try using a different charging cable and charge for some time to see if your earbuds are out of battery. See if charging helps. If not, you can email Anker at support@anker.com
Tenho pedir esculpa nao falo Espanhol.
Sou Alemão e falo um porquinho Portugues
Talvez podes escrever em Inglês.
Mas nao entendo a tua pergunta.
Estes audiofones sao Q10?
Nao existe um modelo nb10.
E nao podes ligar?
Precisamos muito mais informação, faz favor.
Estes audiofones estao carregados totalmente?
Talvez podes usar um outro cabo-
Pretty sure this is what he/she means
Doesn’t exist here.
We got those similar looking curves only.
but he should tell us a little, bit more about the issue?
Or should we use our magic crystal ball.
Yea that’s the reason I just started with the basics to see if we get more info out. We’ll just have to wait and see
