can anyone provide assistance in setting up 2 cameras on using the same wifi? I’ve set up one but now I need to setup my second camera. thank you
assistance required setting up 2nd eufy camera solo
The second one should be similar to the 1st one. Im the app, click the 3 line menu . Go to devices and click the plus to add. Select your device and follow the instructions.
@gar31 As said by @Duane_Lester the setup of additional cameras is the same as your first camera. Add within the EufySecurity app and follow the step by step instructions.
