is there any to customize sounds on liberty air like bass etc.
App for customize the sound of liberty air
I don’t think there is any apps to customize headphones. I believe it only works with the big speakers
There is no dedicated app, but you can always use either your phones equalizer or download one from the app store.
This year, the next generation of Liberty headphones will have an adjustable EQ in the app.
What about Neo’s ???
