Any plans for extern siren
Hi. Does eufy have any plans to release an external siren.?
I have the same question. I need an external siren for for my euftcam and door sensors… the internal it not possible to hear from outside to alert neighbords
Why not integrate the eufy doorbell chime (during software update on both home base and chime) to serve as add-on siren(s) when alarms goes off from eufy motion sensor and eufy entry sensor. At least you can place and plug (multiple chimes) this chimes anywhere in your home.
interessa anche a me…
It’s 2020, will there be an external sirene in the Eufy product range??? Current alarm sound of homebase station 2 is not loud enough.
FOR WHEN???
We definitely need a siren
I would love an external siren for the Eufy security system. Currently have two systems running at home, Eufy for my cameras and another for my alarms. I want to standardise on Eufy but the lack of external siren is stopping me. Please add an external siren asap
You guys should suggest a siren to Eufy through email
