Hey guys, I am buying an Anker/Soundcore product for the first time. I was decided by a Motion Q or Motion B. What would you consider the best when it comes to sound and specifications? What is your favorite?
Motion Q
Motion B
0 voters
Motion Q
Motion B
0 voters
I like the motion Q, small portable and has great bass response. Its also waterproof down to 3 ft for 30 minutes
What is your mainly using scenario? Outdoor or at home?
If you have solely decided on these two models I would lean towards the Motion Q myself, based on the the form factor and audio distribution which echo the SoundCore Flare (which is an excellent speaker too)…
At home and outdoors only on the weekends.
I love the Motion Q with the 16W it has and it is also a 360° Speaker
Clean sweep for the Q.
If your gonna be outdoors then its a no brainer, as i suggested above The Motion Q wins hands down
