Anker Soundcore Life 2 features on TheGuardian.com for best wireless headphones under £100
£66; noise-cancelling ; over- ear; 30 hours battery life
Pearl-effect construction looks dated and the feel is a little rickety – although they come with a carrying case, which should help protect them. They are oversized which makes them a good choice for those with a bigger head – for example, if you take a large-sized cycle helmet you won’t have to extend the arms. The super spongy over-ear cups are comfy.
With the noise-cancellation engaged you lose a little pep but overall the sound is punchy and detailed – optimised for modern, bass-heavy, meticulously engineered R&B but they add zing to most genres.
Verdict: Perfect for big-headed R&B aficionados.
