Anker Soundcore Liberty Lite - Right Earphone not consistently charging
Have had the earphones for about 2 months now.
The right earbud does not always charge when it gets put into the charging case.
This is annoying when you think you have fully charged earbuds only for them to run out of power almost immediately…
Try cleaning the charging receptacles on the buds, and the case.
Take a toothpick and and cotton round (or ball). Roll off a tiny amount of cotton on the tip of the toothpick. Use that to wipe the receptacles.
Let me know if this works, or if you need further help.
You’ll want to check the charging contacts to make sure they’re clean and making a good connection. Feel free to reach out to service@soundcore.com if you still have trouble. Thanks!
I’m having the same problem with my liberty lite buds, I have tried cleaning the contact points on both the ear pice and the charging pod
Try contacting support at service@soundcore.com
