I’ve purchased the Soundcore Liberty air 2, i’m using Galaxy Note 8. When I try to listen to my Music, then i took my earphones out for a second , it did stop the music , but then I put it back and it’s not continue playing the music. Please help me if you know the way to fix it. I did reset my earphones but it doesn’t fix my issue
Anker Soundcore Liberty Air 2 is not continue playing when I put it back to my ears
Thats how they are, they will pause the music but it does not automatically turn them back on. To do so all you have to do is double tap either earbud and they will come back on
