Anker soundbuds sport NB10 is specially made up for the people who are fond of running, jogging and climbing the mountains and get their resilience from music. Therefore they are designed the way it should be, for running purpose.
Anker soundbuds sport NB10 has an ergonomic design, fit nicely in the ear canal. The best part of these wireless headphones is the way they are made up, the adjustable fit clip (adjustable neckband) that runs around the lower head from behind the ears. This fit clip further holds the ear hooks that runs over the ears and then all the way goes to your ear canal; a perfect and secure fit.
In addition, this clip is adjustable and very flexible, make them loose or tight just according to your size of the head. Whatsmore, Anker soundbuds sport NB10 comes with three different sizes of ear tips as well, you can customize them the way you want them to be. Further, there are three tiny buttons on the right earbud; for play, pause, volume adjustment and talk over the calls through the built-in microphone.
Visit here to read about Anker Soundbuds Sport NB10 Performance
