Hi, I have been an active Anker community member and noticed I had some reward tokens for money off on Anker goods. Unfortunately these only seem to be US only and as I am based in the uk can’t use them . Are there any plans to allow uk users use these vouchers ? thank you
Anker Rewards
Maybe try emailing anker support and explain your situation and see if they can help come up with a solution for you. Doesn’t hurt to try
Yes, please contact support@anker.com to restate your issue, I think my colleague will glad to help you!
Many thanks will do
I would try contacting anker and finding out what you can do about that.
thanks all Anker have confirmed not available for use in UK as yet
