Hello,
I have a apple macbook that is connected via USB-C to a LG 4K 27" monitor (27UD88-W). At the moment it supports power, display and ethernet (USB3.0 to ethernet hub) all through the single cable.
I’d like to know two things:
If I connect my macbook >>>> via usb-c cable >>>>>>input anker usb-c port >>>>> output anker usb port >>>>>LG 4k usb-port. Will my macbook be able to send the display output via the anker to the LG monitor?
If I connect my macbook >>>> via usb-c cable >>>>>input anker usb-c port >>>>>output ethernet >>>>> network switch. Will the anker pass throgh network connectivity to my macbook and bypass the LG monitor.
At the I’m using a USB 3.0 to ethernet adapater, which is connected to the back of the LG monitor, the ethernet speed is restriced as the LG monitor is acting as the bottle neck. I’m wondering if the anker hub adapter will bypass the monitor completely.
Thanks.
