Anker PowerExpand Direct 6-in-1 USB-C Hub Unboxing + First Impression
Finally the Anker PowerExpand Direct 6in1 Hub arrived in Germany. I really like it alltough it s a little bit to loose at the USB-C Port of my iPad Pro
Took a first look.
Will tell you more about.
greetings from München
Franz
It needs to be sufficiently lose to not damage the iPad when a force is applied vs not so lose it falls out easily.
The safety won t help you if you have problems to keep the USB-C hub in your iPad / notebook :wink: I think there is still room for good sticking the hub in the device and still provide some way of safety.
