Anker powercore+ 26800 PD does not charge laptop
Hi everyone,
I have an issue, when i connect Anker powercore+ 26800 PD to my Dell Vostro 5370 using usb c port power bank gets charged from laptop’s battery and I cannot get it to work the other way.
I have tried different cables including Mac Pro original power cable, cable that came with the power bank, and other usb-c to usb-c cables.
Also laptop is charging with no problems using mentioned cables when used with wall adapter (except from the one that came with powerbank).
Have anyone find a solution to this problem?
cheers!
You need to press the power button before plugging it into your computer in order for the Pd port to send power out. When trying to charge the powercore you want to make sure all lights are off when plugging it in in order for it to accept the charge
As @Tank correctly say, the USB PD port is bidirectional, two modes either input or output.
It defaults to input itself being recharged when connected.
If you want it instead to output power then press the power button before connecting.
If it’s still thinking it’d meant to output power by the lights still being on and you want it to go back to it being able to be recharged then wait until the lights go out.
If you have used the trickle charge mode then undo that to let it turn itself off before the above.
even when I try this, it doesn’t work. I turn on the charger and then plug it into my computer and the lights just turn off on the charger and it goes back into charging mode
i have the same problem with my HP Stream Laptop 11-ak0029na with Microsoft 365 Personal … the Anker Powercore only wants to charge itself up when connected via usbc to the laptop. No matter if the light is on or if the power button is held down until there is a single green light (whatever that means!!!) it still charges itself when plugged in instead of charging the laptop. I only bought this anker powercore because it’s high spec enough to charge my laptop. What a waste of money. The best help i can find is some indian guy off youtube telling me to factory reset the laptop which will obviously erase my stuff.
Of course dont do that factory reset. :roll_eyes:
May be there is a possibility to check the power/charging options in the WIN-settings.
I dont know not using WiN anymore since many years.
Those could also been found in the BIOS-specs.
Depends on the BIOS of the device.
Btw: Have you contacted the support?
May be they can help you.
