I have Anker A7726 which is paired with my MAC. It was working fine for an year and then few keys stopped working. I tried to power off/on, pairing and keyboard settings to US. But none helped. I have problem with only the below keys.
Tab, a, q, `, 1. All other keys are functional. Appreciate the help in resolving the issue.
Anker A7726 few keys are not working
Are the keys sticking? Or just don’t work? Email Anker at suppport@anker.com and they will help you troubleshoot.
Do those keys work at all or give different characters when typed?
Check your settings and make sure its set to US keyboard layout.
Have you tried pairing to a different device? We need to know if its the keyboard or something changed on the mac
They just don’t work.
They are not working at all.
Yes, i tried with an windows laptop. There also these keys are not working.
The keyboard settings is to US layout.
Thanks a lot, i sent an email to support.
