So sorry to know you have trouble using your wireless devices with your hub.
Please know that Bluetooth devices (such as a wireless mouse or keyboard) use a specific radio frequency to talk to each other. It’s a bit like the old AM/FM radios but at a much higher frequency that humans can’t hear.
USB 3.0 devices naturally use cables, however, the cables and the devices connected at each end generate electrical noise over a range of radio frequencies. Unfortunately, the range of frequencies USB 3.0 is allowed to use conflicts with the specific frequency all Bluetooth devices use. This means that any USB 3.0 port, cable or USB 3.0 device can emit radio frequencies that may cause interference with any Bluetooth devices you use in your computer.
The end result is that your Bluetooth device(s) may degrade in performance, like what you are experiencing. To help inform buyers about this, we put the following information in the product’s listing information:
“2.4 GHz wireless devices, MIDI devices and some USB 3.0 devices may not be supported. Try using the host port or a USB 2.0 connection.”
Currently, it is a general issue for USB 3.0 devices. It may help if you use an extension USB cable for this USB 3.0 hub or you can try a wired device if you have one.
We hope you find this information helpful. For any other questions or concerns please do not hesitate to contact us–we’re always here to help.
