Android EufyCam Custom Notification Sounds
Will the ability to add additional/custom notification sounds from the Android OS ever be enabled in the EufyCam App other then the current basic list?
I and many others would really like the ability to select custom notification sounds for each camera to help identify which camera has sent a notification. I currently have seven cameras and it would be extremely helpful to have the sounds indicate which camera has been triggered so we may respond accordingly.
Thank you!
good job. my dear
Good idea :+1:
In November, 2021 I received a response from [support@eufylife.com]when I requested this enhancement: “There are no ways to either use the standard Android notification sounds for individual cameras nor import external sound files into the Eufy App. The issue will be forwarded to “engineering” . . .”
I’ve heard that before.
Hi there,
Great job you have done your work nicely, I have already heard about it before many times I have tried many times to do it but could not do thisread more
