All Eufy Cameras
Hi,
I have been looking into purchasing 1 or 2 of the different type of cameras but due to the current climate with the global issue, unfortunately i cannot afford to.
The Eufy cams generally come wit a homebase unless they are add on cameras.
The doorbell camera and the floodlight cameras seem to be standalone systems.
As these days, security and privacy is key to everyone.
Why do the standalone cameras not have a homebase delivered with them to keep their recordings safer?
In addition, if all of the cameras were able to connect to 1 homebase, it will create a full system hub similar to the old CCTV systems and each additional camera can be purchased as add on items.
Some cameras do not have the option to expand memory using a micro sd card, which would be useful especially if an incident occurred but wasn’t taken notice of and the recording was over-written.
These are just a few thoughts i had off the top of my head.
Thanks
Hi @Mustafa.arif, thank you so much for your thoughts and concerns regarding eufy cams, I will forward your suggestions to our technical teams. Thank you again for your thoughtful advices :smiley:
