7-port USB Hub erratic with my Mac
Hi,
I have two of the 7-port USB 3 hubs - one at home and one at the office. I use them with my Macbook Pro and have constant problems getting external hard drives to mount via the hub. I try a variety of combinations of plugging in the drives first, then the hub into my computer, plugging and unplugging. Eventually the drives mount, but I can’t find the pattern.
Anyone know why the hub is being so finicky?
I’m running 10.11.6 on an early 2013 model laptop
thanks!
Will
Hi @will.yurman,
It sounds like you might be running out of power. Are you using one of the powered USB hubs (one that comes with an AC wall plug)? Would you mind posting a link to the particular hub you have? Also, how many drives are you connecting?
https://www.anker.com/products/taxons/114/Connectivity
Thanks!
