Hello does anyone know why my eufy cam 2c only records 5sec?
5 secondes record
You may have optimal battery life set up in Camera Working Mode or if you use the customise recording setting, recording stops when no movement is detected by default (you can deselect this). Both can give you the 5 second recording scenario.
Thanks for your feedback. I resettet the home base 2 times and now its working perfect. I Will try your options if the problem is comming back .
Nick
