I’m looking for a 5 meter USB 3.1 cable that will be good enough for using on my Xbox controller for FPS gaming (so, no lag if poss).
Does such a thing exist?
Couldn’t you use a long micro usb cable right?
Well, I think so, but I don’t actually know much about cables and I don;t know if I’d get input lag from using a ‘normal’ cable. So really I’m hoping someone can tell me what I need
Got I use to just use a long micro usb. For the length though you would have to shop Amazon probably. Anker does have a 10 ft cord though that’s good.
[Micro usb here](Anker Powerline+ Micro USB (10ft) The Premium Durable Cable [Double Braided Nylon] for Samsung, Nexus, LG, Motorola, Android Smartphones and More https://www.amazon.com/dp/B019Q6Y2MK/ref=cm_sw_r_cp_api_i_hEL6Db2ZDCKE5)
3 meters is about the limit where transfer speeds will be an issue. If you are gaming and want the fastest possible speeds I would be wary of anything over this as you will lose precious response time.
