I manually charged the vacuum today, lights were on during the entire charge. After using the robovac, I pressed the button so it would return to base and charge. After a while the lights on the robovac turned off, is this normal?
Thanks.
Thanks.
Hi @bbnielsen
No,I don’t think it is.
Just checked mine, it’s fully charge and has been docked for 3 days without use, and my light/button is blue.
Maybe contact support@eufylife.com for further advice.
Thanks. I flipped the switch on the bottom to reset it and that seems to have worked. Blue light all night long
