Hi,
I use localcast or bubbleupnp on my tablet to stream my movie with subtitle (.srt format) on the Nebula.
The audio/video works fine but the subtitle doesn’t appear.
Has anyone encountered this issue?
Thanks
Hi,
Thanks
Which projector model do you use?
A nebula capsule with the last version.
I can check the version later.
My current version is : nbui m1 v1.0.83
Thanks
My current alternative is the reverse the streaming process.
I install Kodi on the Nebula Capsule. I enable UPNP in the service settings.
I run Bubble UPNP on my tablet (with UPNP server enable).
In Kodi, I add the UPNP source in the video (I select my Bubble UPNP from my tablet).
