If you’re experiencing a problem with your Soundcore Liberty Air 2 earbuds, specifically the Soundcore Liberty Air 2 right earbud not working, here are some detailed steps to troubleshoot the issue:
1. Reset the Right Earbud:
- First, ensure the right earbud is turned off.
- Open the charging case and place the right earbud inside, leaving the case lid open.
- On the top of the charging case, locate the power button.
- Press and hold this power button for at least 10 seconds or until you observe the case’s light flashing three times.
- Keep the case lid open until you see one light flashing rapidly and another light flashing slowly.
- After this, carefully take the right earbud out of the case. It should now be reset.
2. Connect Both Earbuds Together:
- To ensure both earbuds work together correctly, you must connect them simultaneously.
- Begin by turning off Bluetooth on your device to avoid any conflicts.
- Make sure both earbuds have enough battery charge by placing them in the charging case.
- Remove both earbuds from the charging case.
- Wait for approximately 10 seconds, watching the earbuds’ lights. They should enter pairing mode during this time.
- Now, turn on Bluetooth on your device.
- In your device’s Bluetooth settings, look for the Soundcore Liberty Air 2 earbuds and connect to them simultaneously.
Following these detailed steps should resolve the issue of your right earbud not working in your Soundcore Liberty Air 2 earbuds.
Extra Quick Tips
To address the issue of your Soundcore Liberty Air 2 right earbud not working, Soundcore Liberty Air 2 left earbud not working & Soundcore Liberty Air 2 one side not working, try these steps: Begin by resetting the earbuds and ensuring they are clean, gently tap the earbud surface, remove any stickers that might interfere with sound, and turn off wear detection if it’s causing problems. Make sure both earbuds are charged properly, and check for any available firmware updates. Additionally, confirm that your device’s audio balance settings are correctly configured. These steps should help you resolve the issue and enjoy both earbuds working together seamlessly.
