Zolo Liberty plus max volume low
I just bought these Anker Zolo Liberty Plus 2 weeks ago and over the last two weeks the max volume has seemed to lessen and get quieter over the last few days, its definitely not the ear pieces cause they are the same ones ive suited for my ears
As far I remember there were some suggestions about cleaning the earbuds here at this forum.
May be you should seek for.
