Here is my review on the Zolo Liberty+
Aesthetics: The case feels great and very premium, although very large and heavy. For me, the bulk and weight is fine, and well worth it considering battery life. The earphones themselves are well made and, but a little bit large in the ear, although not too heavy.
Durability: I’ve dropped the earphones multiple times and they’re holding up great. I’ve never dropped the case, but it’s so heavy I’d assume that it wouldn’t make it out in one piece if I did.
Audio: It’s very good, with great clarity. The bass is a bit lacking, but I’m sure most people will find it fine. The earphones do a great job at sealing out ambient noise as well.
Battery Life: In my testing, I usually got just under 3 hours with them, but I never use them for that long, and the massive 48 hour capacity of the case keeps them charged.
Connectivity: By the time I’ve taken the earphones out of the case and put them in my ears, they’re usually already connected to one another, and my phone. Unfortunately, not every time I take them out of the case do they turn on automatically, and I’ve tested three different pairs on this issue, and it was prominent in all of them. Once they’re on and connected to my phone, I’ve never experienced connectivity issues, probably thanks to the Bluetooth 5.0.
Transparency Mode: Clearly not a lot of thought was put into this. I don’t hear as loud as I do in real life, and the volume can’t be raised. When I have it activated and I’m listening to music at around 70% volume, I don’t hear ambient noises, but only an annoying hiss, so I turn it off. At this point, it would be faster and easier for me to just take one of the earphones out of my ear to talk to someone then to turn on transparency mode.
I give these a 6 and a half out of 10.
Hope you enjoyed! Merry Christmas!
