Zolo Liberty+ Issue - Lower volume on right bud
Ok, so its April 2019 and i have this problem, so its never been resolved.
I had to take off the gold mesh and saw a lot of gooey glue spread across it. I carefully scraped it all off, and bingo it works fine, FOR NOW.
Had the same problem with the right earbud, soaking and cleaning with Isopropyl alcohol helped and it sounds at about 90% of original volume, which is a considerable improvement.
I had the same problem…use a small needle to take off the screen then a q tip to clean screen and inside,volume went back to 100%.
