[YMMV] Soundcore Liberty Air 2, ONLY $59.00! (US)
Soundcore’s Liberty Air 2 is on clearance for just $59.99… That’s the lowest price yet!
Buy at Walmart
Features & details
  • Diamond-Coated Driver: Liberty Air 2 wireless earphones take advantage of the ultra-light, yet rigid structure of diamonds to create a driver dome that maintains its rigidity, even when vibrating at high frequencies. It produces sound with flawless accuracy and treble that sparkles full of detail. Around its exterior is an elastic, bass-maximizing ridge to reproduce thumping low frequencies.
  • 4 Microphones for Crystal-Clear Calls: Each earbud is equipped with two microphones that utilize the latest cVc 8.0 noise reduction technology. Your voice is optimized and background noises are minimized so you sound louder and clearer on the other end.
  • Up to 28 Hours of Playtime: A single charge gives you a full 7 hours of listening, while the charging case extends it to 28 hours of playtime. And when the case needs a power boost, simply set it down on a wireless charger.
  • HearID Technology: Take the test to create a custom set of EQ settings that are optimized for your ears. HearID maps your hearing sensitivity at multiple frequencies and intelligently analyzes the results to give you a truly personalized listening experience.
  • Advanced Chipset: Liberty Air 2 wireless earphones uses Bluetooth 5.0 and aptX audio for the strongest, most stable connection and lossless sound transfer when streaming media from your device.
Saw this yesterday , showed as out of stock :frowning:
this varies by state and zip code… so might be still available for other areas.
Absolutely, and what a steal!
Sweet color!
