Why I think a 100W Powercore 26800, 60W 20Ah and 30W 10Ah is coming June
You’re too smart, @professor.
This is how I’ve been operating the past month. Charging 2-3 minutes at a time. Ok, more like 5-10 minutes. 18W PD charging is a godsend.
So imagine if in 2-3 mins you got actually 30W but the electronics when they sense getting too hot then sustained 18W later…
It matches how you operate. Matches how your phone and laptop operate. Heat pumps.
If I’m thinking it, someone deep inside Anker is already. What would need testing is the thermal throttle, so you in a lab take a high Wattage load and confirm the throttle does not melt charger, so lots of deep recharge cycles and crack open and look for melted contacts. I can see thermal throttling to take at least a month more testing. If Aukey shipping this week, Anker a month later…
That’s. Good bit of useful information there,
I can imagine that’s the future to have 100W Powercore
So I have been doing some research on the electronics within a 100W PD Powercore.
It looks like it will have to ditch the Type A port as there’s a choice between tuning how the cells are wired to be best at say 20V or best at a lower voltage but not both. The more you get to 60W and above the more you really need to drop all the lower voltage modes and drop 5V altogether.
This may also explain a puzzle I have had with the 18W PD + 10W Powercore, they seem less efficient, like serving both 9V and 5V is a stress. The more they go up the bigger the stress. So they’d need to tune the Powercore 100W PD to be for say 20V and 15V and ditch 9V 5V.
I hope Anker sells a 100 watt wall plug soon, everywhere else is so expensive
I dont follow, Anker is not the lowest cost brand.
I hate to break it to you @professor, but Anker is preparing to release a 60W version soon. Details to follow…
20Ah?
The MOSFET efficiencies suggest the wider the voltage range the worse the efficiency of one or both. So as they get more into the 20V modes (required for laptops) the more they need to drop the Type A port.
Or in different words, 60W Powercore have to ditch the Type A port.
Example http://www.ti.com/lit/an/slva390a/slva390a.pdf?&ts=1589322110680
Larger :wink:
So a respin of the 45W 26800. It suffers from inefficiencies. A 26800 60W with a Type A port would deliver comparable energy to a 20Ah which drops Type A.
http://www.ti.com/lit/an/slva535b/slva535b.pdf?&ts=1589322440429
This voltage difference, which lowers efficiency, is why Anker 9V + 5V Powercore output fewer Watts when you use both 5V and 9V ports. One port 18W, both ports combined 15W.
95% efficient 100W PD does exist. This one $4/unit , so I don’t see a reason for a $99 100W charger from Anker…
Later today… :shushing_face:
How do you know? They tell you directly or you subscribe to something?
My future looking glass is logic and electronics.
Released separate or in a bundle?
Last version released 7 months ago as bundle for $140
I think released with a bundle makes sense for those who choose to not think, prevent them getting no or incorrect charger, but there should also be a release without a charger so consumers have choice.
Cells choice:
  • Anker traditionally used LG 18650 3350mAh cells, 8 of to get to 26800. These can discharge at upto 10A 3.7V so 30W per cell or 240W output over 8 is possible theoretically but heat would make you want to do much less. 100W is highly likely safe and reliable.
  • if they get custom Lithium Polymer cells made they can tune the shape for best thermal conductivity for more headroom than above.
Output Wattage.
  • this is just a question of tuning. You can tune for 60W, 100W but you lose efficiency at other levels.
  • there is no inherent reason why 60W has to be difficult or expensive, what makes it challenging is if you allow for multiple ports and of you tune it for lower voltage and so it gets hotter for higher Voltage.
  • personally I’d ditch the Type A port and tune for 20V, it would last longer and be better high Wattage product.
Input Wattage
  • personally I’d use a thermal feedback sensor so you let the cells tell you.
  • Anker never done this, so they test and find a consistent reliable charge rate and ship it as fixed.
  • Anker does safe and boring.
Nah, I’m just posting about it today.
How are you finding this out, Anker send it to you as an insider?
Same way I find out everything. Lots of searching.
Ok.
I also search but obviously less good at it.
Anker is so far behind the competition is already discounting theirs they released earlier.
