What to use to charge Powercore speed 20,000 mAh (Upgraded)
What is the best device to use to charge the powercore? What’s the max input can it take?
The Upgraded PowerCore Speed 20000 QC can accept recharge via Quick Charge 3.0, so if you’re seeking a solution by Anker, I would recommend something like this or this.
If you wish for more ports, please let me know and I can make some additional suggestions.
Hope this helps, and feel free to reach out if you have any further inquiries! :slight_smile:
Josh
Sorry, not sure if I understood correctly. So you mean I can charge the powercore using the “IQ” port instead of the “input” port?
No, you charge it through the input port. The input port supports Quick Charge 3.0
The input can take 5V ⎓ 2A, 9V ⎓ 2A,or 12V ⎓ 1.5A.
It will charge optimally with a Qualcomm quick charge 3.0 charger.
I use the Anker PowerPort 5, the 2 blue slots. Its charging very fast and doesnt get hot
