Exactly guys!
In my case, i would need the EUFY SMART WATER (LEAK) DETECTOR for this:
I have an old heating cellar, which is about 1 meter lower then the regular basement rooms. And this heating cellar gets flooded by backwater 1-3 times a year, when we have extremely strong rain in a short timeperiod. Then we have this case:
So i bought a ver strong and good dirty water pump, which can not only help to get the water out of the basement, it will also help to safe the heating system and other electronic equipment if i just start early enough to pump out the water. As faster and earlier, as less the water will climb in the basement.
Therefore, i would need a wateproof and silent water detector !
- Waterproof, because it will be defenitely under water for some time
- Silent means: Option to only be alarmed/notified by the app (instead of the detector making alarm only or too)
- And if it would be an eufy water detector, i could use it in the eufy cosmos and also in the already used eufy security app and just add it like a door sensor or eufy security cam.
As far as i have seen now, there is nothing on the market which fits my needs in this case. Sure, there are tons of watere leak detectors availabe already. But either they are not waterproof or the sensor/detector always alarms too (what i dont want).
So it would be a realy useful, very fast to develop and kind of cheap security “widget” in the eufy security cosmos and could be easily implemented in the already available app.
