Hello, Guys! I just want to know that should I charge my Anker Soundbuds with my Anker Power Port + Wall adapter or with a laptop? Which will be better for battery life? Please answer someone? Laptop port draws 400 mAh whereas Anker wall adpater is 2.4 Amp. So which is better for battery life for my SoundBuds? Thank you!
What is best way to charge my Anker Sport SoundBuds NB10?
Charging at lower amperages will prolong the battery’s lifespan.
For charging on the go I recommend the new PowerCore light 10K or 20K with trickle charge mode or the PowerCore+ mini. Larger power Banks have a higher cut off and will not fully charge your headphone battery except the PowerCore lite.
