Can someone here explain #2 ?
I always leave my cables plugged in at my house…
Here are some tips to help you get the most out of your PowerLine+ II
- The Lightning connector is not waterproof. Please avoid storing your cable in high-humidity environments.
- Remember to unplug the cable from the adapter when not in use.
- To ensure the cable’s longevity, do not abruptly bend or pull the connector. Do not expose your cable to the elements for long periods of time to avoid moisture collection and rust.
- Keep your cable away from pets.
- Use 99% v/v alcohol to clean the Lightning connector surface occasionally.
Regards
AnkerDirect Customer Service
