Hi All,
I did try searching for this so I hope I am not repeating. In the manual for the Soundcore2 it tells me to hold down BT button for 2 seconds to Un-pair. When in fact that does not work, but double tapping BT button does. Just thought you would like to know.
Un-pair incorrect manual info
Hi @sbooder,
You can try it by pressing the volume +/- button at the same time for 3 seconds.
And let see if it’s work!
