UK 22% Off PowerCore+ 26800 PD and 60w Charger Amazon Bundle Deal
That is pure genius @professor
Made Debs and i LOL and almost ROFL :sunglasses:
Maybe a post Christmas deal on the Atom III Slim 63w?
Or maybe see it’s upgraded brother?
Nice deal! :+1:
Cheers buddy @QueenMagic
Nice deals
Thanks @Mike246810
Always finding nice deals!
I do my best @QueenMagic
Hehehe! :rofl:
Ill add this to the collection :sunglasses:
Are there any power banks that have USB-C output?
Ooodles.
How much wattage do you need? There’s 10W, 18W, 27W, 45W, 60W…
Best value for money right now is 18W.
I have an iPhone 11 Pro and an iPad Pro (2020), so I could roll with 18W, but more if I’m to take advantage of the iPad’s fastest charging capabilities. Do you have any recommendation, please? (I’m switching all my cables over to USB-C on the power source end).
What is the minimum and maximum USB-PD W of the iPad Pro 2020?
It is slightly different between a portable charger than a charger. A portable charger you ideally seek the lowest supported Wattage as that tends to be cheaper and (by definition) it is with you all the time so just connect it for longer. A charger is tied to a wall and (by definition) you’d want to connect for the shortest time. So chargers tend to be the ones to support your maximum, portable chargers your minimum.
So what is your device min and max?
My USB-C devices have a min of 10W and a max if 18W, so I tend to use the 10W-18W Powercore and all my Powerport are 18W.
Apparently the iPad Pro 2020 supports charging speeds of up to 35W, though maintaining 30W throughout. It ships with an 18W brick.
Cost isn’t so much a problem, but I would want fast (tethered, albeit portably so, is still tethered).
Just whilst I’m typing and because some of you are very knowledgeable, would you happen to know the cable length on the Atom 4, please?
Default C8 cord is 5ft, you can always buy a longer.
Cost isnt a problem? 35W+ ? You’re in UK?
So for example this very thread deal match’s your needs.
Thanks. I did just notice the Atom takes a C7 cable, so will pick up a longer one.
The Powercore+ item/deal in this thread only has a single USB-C output port. I was hoping for two.
Which Atom exactly? I’d be guarded buying the Atom PD4 and instead go the Slim 65W or 63W corded.
Yes. I did mean the PD4. Why guarded about it, please?
